Adding Batt
I'd make sure to fuse them up pretty well. I'd put a pretty big inline fuse on both ends of the positive terminal if it were me and the two batteries weren't directly beside each other... don't want to risk that wire shorting in the middle and starting a fire at either end of your wire.
Might want to look into a battery isolator if you are going that route - heard they tend to burn up though just an FYI.
Also, I would make sure to connect the grounds with a wire instead of just grounding both them - car isn't as conductive as thicker wire normally supposedly.
parallel them together and what ever the last batt in the bank is conect all your amps to it. That way you have an = charge/flow though your batts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mrose
DEEZ
mrose
MN
ironchef b
