Adding another battery, Kinetik. Model ???
94'BLKBRD
So Cal
Adding another battery to my car. Confused on the Kinetik model #'s.
I want the Kinetik KHC1400, but I found a marine battery that's the same price but it's 1800 amps, KM24.
Should I go KM24 or KHC1400? What's the different with the Marine battery?
They're around the same price($4-6 difference).
KM24
http://www.sonicelectronix.com/item_10462_Kinetik+KM24+-Marine-Add-on+Equivalent+to+HC1800%2C+but+with+Square+Type+Posts-.html
KHC1400
http://www.amazon.com/exec/obidos/tg/detail/-/B000LUBQ4S/ref=ord_cart_shr?_encoding=UTF8&m=A3H89ADJHTH9SN&v=glance
I don't know which one you should grab, but they're not the same price. The HC1400 is $150 shipped, and the other is $150 + shipping. after you add that on it'll prolly be $30-$60 more.
And the hc1400 also comes with wingnut terminals, not the standard battery posts like pictured. I ordered one a few weeks ago.
I would venture to guess that the kinetik would be more reliable in a car audio application.
Considering thats what they're made for. Its sort of like using a napkin instead of paper to write on. Yeah it'll work...
So does anyone know if I can use the Kinetik KM24 marine battery(same specs as the HC1800) in my car?
I have a red top up front that works great, just want to add a deep cycle battery. I also know that I will have to use an isolator.
P.S. The KM24 is $100 cheaper than the HC1800 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How much power? If you're doing okay with just your redtop, you probably don't need that big of a battery. I'd just stick to the kinetik...tried and true.
And you don't need an isolator.
what car and size alternator? with 860 watts, a second battery isn't quite necessary. have you've done the "big-3" already too?
i've done the big three
1998 camaro z28
alternator is 110 amp
Should I just replace the red top instead of adding a second battery? I mean, a second battery isn't going to hurt and I can use the red top up front(starting battery)
825
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
737
Thanks. That makes sense. It sounds pretty good as is.
942
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
94'BLKBRD
94'BLKBRD
So Cal
audiolife
    May 18, 2024
    May 16, 2024
