Adding Another battery and Big 3
Bobby322
Im going to be running ~2400W daily. I plan on doing the big 3 and adding another battery. I dont exacally thick wire yet, but im thinking about doing it with what I have right now and upgrading it when I get 1/0. It is this store bought stuff with terminals on each end, not too thick at all but I guess its better than nothing.
How big/model do I need of a battery for the amount of power im running? How exacally do I wire up a second battery?
If you do not have at least actual 4ga, I would not even mess with the big three
Big 3 in at least 4ga and 0 ga between the batteries and amps.
Underhood battery+ -fuse-------fuse--back battery + (both fuses within 18" of each battery)
Underhood battery neg too back battery neg
I would use atleast a group 27 sized agm like a kinetik HC2000 or a group 31 sized hc2400.
I would use atleast a group 27 sized agam like a kinetik HC2000 or a group 31 sized hc2400.
So the under hood + connects to the under hood + with 2 fuses. and just connect the neg. and neg. of both batterys together and the back battery will ground through the front?
2400W is how much i'll be running.
Bobby322
Bobby322
TX
Bobby322
