Adding a third RE SE worth it?
04silverz
Currently have two 15 RE SE dual 4 in a sealed box in the back of my truck. These are the last gen ones, the ones right before the *** came out. Box is definitely on the small side, only like 4.25 or something after displacement.
Whether or not I add a third I will be going with a bigger box. Plesae don't mention ported as I don't want a ported box.
Thinking about adding a third but power may be an issue.
I don't have the money to buy a new amp and currently have an orion 2500d.
Amp puts out 1200 at 4 ohm, which I'm wired to right now, and 1700 at 2 ohm. So I would basically be running somewhere right in the middle if I add a third sub right? Seems like they would all three be underpowered so would adding a third sub thus making them all 3 underpowered be noticeable gains or just go with the bigger box.
Or I could run the amp at under 1 ohm but I don't really want to do that either. Plus I think that would be overpowering them quite a bit.
Cliffs notes:Add a third sub making them all underpowered and adding more sq. ft per sub or just add more sq ft per sub for the two I already have.
04silverz
04silverz
San Antonio
schackel
