added fan to amp it went into protect mode y ?
one or two runs of 1/0 gauge to the rear where you will have one or two large sealed agm batteries. from the batteries, one run of 1/0 to the rd amp and one run of 4 to the pa amp. grounds for the two amps returning to the rear battery bank. you will also need to do the big three under the hood.
and finally...
you will need to find someone to do this for you, for your own safety. you clearly have no idea what you are doing. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
oh, and fyi, you wouldn't need a fan to keep the amp cool, if your voltage wasn't dropping into the 10's...
^This^
I think you need to get a number from one of these helpful gentlemen because if not this is gonna be a 1000+ page thread...but like i said earlier..."This". //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
scoshe 5 ga. Kicks ***. LOL. But seriously i'm using 2 runs of it to run 4 amps. 2 MTX BTP 75x2's powering one 15 (Don't ask its all i have right now and i dont have money for a sub amp just yet) and 2 PPI Power class amps on my highs. and with those small amps i get down to 11.9 volts under full load. so just think about it for a second..........2/37.5 watt per channel amps , a 50 per channel , and a 75 per channel. all together its around 800 watts. (The mtx's are bridged and also under rated). so if i drop under 12 with 800 watts , imagine what your ride is doing with a 2200 watt amp running in it.
when i add my new battery ill be fine with 2ga since my stock battery isnt wired with 0
so your saying i ground my amps on the neg of the new battery but where do i ground the battery too
go **** yourself you dumbass you should be thankful that RD used to make good amplifiers because the shit you had shouldve toasted completely
and on a side note i dont feel like reading 4pages of your retarded responses and excuse's for running your system like a dipshit.
i have money ***** i just dont feel like waiting to get if i order it from the internet and plus what the difference its only 2 numbers away like i care nothing is going to happen
your the one that knows nothing how the **** was it going to toast lol you idiot
oh you better watch out dude its going to bblow up your lucky your whole car didnt explode you didnt use ******* guage wire
markak134
Banned
markak134
pa
LazyRider
