add on tweeters
loud-n-low
i give ladies 30mm xmax
im looking to add tweeters to my existing setup, and not sure what to buy. Boston acoustics makes imaging tweeters, but im looking for other companies that sell tweeters with crossovers. woofersetc sells image dynamics tweets but i dont think they include a crossover. do i need a crossover since they will be hooked up to an aftermarket amp?
im adding these to my front end which consists of 6.5inch 4 ohm coaxials. im tapping in to the coaxials with the tweeters so will that make my amp see a 2 ohm load if the tweeters are 4ohm?
If you wire them parallel your amp will see a 2 ohm load, if you wire them in series your amp will see an 8 ohm load.
I used to just have 6 1/2 3 way eclipse coaxials and I added the jbl tweeters and I noticed a huge difference.
my car is a lease, so im not doing anything major. some add on tweeters are 8 ohm, some are 4 ohm. not sure which would be better as an add on due to combining them with 4 ohm coaxials
loud-n-low
loud-n-low
upstate NY
loud-n-low
