add on tweeters
The Boston Tweeter set is 8 ohm, and you can set the crossover point for either 8 khz (imaging mode). Or, 3 khz (SPL mode). There is also a tweeter attenuation switch to set the output level.
If you have a 4 ohm set of comps, the amp will see a 2.66 ohm load in the 3khz range & up. Most any amp will handle that.
loud-n-low
i give ladies 30mm xmax
loud-n-low
upstate NY
loud-n-low
