actual output of a JBL 1200.1?
solobaric12
I am wondering if i hook my 2 Kicker solo-baric L7 12"s up to my Jbl 1200.1 with each sub wored at 2 ohms, will it put 1200 watts to each sub? since the amp has 2 speaker outputs? or should i wire them together at 1 ohm? yall keep talkin me to do it at 1 ohm, but i dont kno if my alt. can handel the power or not.... & if i just want to hook 1 of the subs up how should i do it? they are dual 4 ohm subs.. please help....
1200.1 puts out aprox 1300-1400 watts.....it has 2 output options for wiring ease....so it only puts out 1200 x 1.....probably going to need a new alt or current one rewound...the jbl can pull 114 ampers max at 2ohms...
I've heard 1380 at 14.4v... Whatever it is it rocks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok lets say it puts out 1350 watts just to make it easy. If you are running 2 subs....that means it is sending 675 watts to each sub.
Originally posted by donlovescaraudi 114 amps? acording to the manual the 1200 pulls a max of 58 amps class d baby!!!!
haha maybe that is at 4 ohms....cuz if it only ****** 58 amps i wouldnt have blown my 105amp alternator. I wouldn't even be dimming at 58 amps.
https://www.amazon.com/dp/B0CJB5TTPB/?tag=caraudiocom-20
8
170
6
562
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
12
solobaric12
solobaric12
Dixon, Ky
rco8786
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
