Active sloping
From what I have seen, usually you put steep slopes for the sub. Helps to create "invisible" bass that you can't detect, so crossover fairly low, no higher than 65-70 IMO. Also steep slopes for the lower high pass of the mids, 18db or higher. For the upper mid lowpass use a less steep slope to blend to the tweeter 12b or so, then for the tweet high pass use a steep one for protection...
Hope this helps...
One more thing, for the mid high pass it all depends on if your doors are deadened and how low you cross them over. You dont need a steep slope if your cross at 80hz or higher, but I would advice using a steep on if you cross lower, like at 60...
Helps to create "invisible" bass that you can't detect.
That's funny right there.
The answer is use whatever slope you need to protect the drivers at the freqs in use and still have it sound good. If you're pushing the low freq limit of a driver with the HPF, use a steeper slope. Typically you'll use a steep slope on the sub to keep the higherfreqs from getting to it and dragging the image to the rear.
Honestly not my terms, I can remember who said it....seemed fitting though //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
O and BTW by detect, i meant the location //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Just realized my description was kind of vague...
actually you'll need to really sit down and listen to how the drivers perform in their locations. I assume its a 2way setup so its fairly easy to do it. You will probably spend the most time tweeking your midrange driver out. For tweeters i would try crossing over at about 3.15khz with a 12db slope and see how that sounds. Some may need a higher crossover point just depends on the tweeter.
As for the midrange I would try on the high end something below the tweeter crossover point, like 2.5khz at a 12db slope. on the low end, honestly I would try at 100hz and go down from there, just don't go to low because unless you have made pods or your doors can handle it, going to low may cause distortion and/or make the door really flex. Unless you have a very well sealed door i would not go below 80hz.
Also remember when changing the slopes, this could change how the driver performs, so its best to start at a good general setting and go from there tuning it by ear or rta.
bitlord
bitlord
Toronto, ON
helotaxi
