Accurate Cuts...
lbjshaq2345
...Must be nice.
On the right side of my box I have a 1/2" lip that I didn't notice until I already glued the side wall on. The inside dimensions are perfect, and everything else is perfectly lined up except this. Just wondering what the best solution would be. Someone suggested sanding it down, someone else suggested getting a 1/2" thick piece of MDF and cutting it to fit there.
...Must be nice.
Cut it off or put carpet over it.
Well I have a router, but no table yet so while that seems to be the best bet, not possible in the time frame I want to get this box done. The whole box is going to be covered in a thin layer of closed cell foam and some sweet poker table felt over that.
flip the box upside down and use the flush trim bit. you wouldnt use a table for that. the ball bearing rides against the wall that you want that piece sticking out to be flush with
beat me to it.. fast like ninja
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
seriously though, flush trim bits are like magic when it comes to inaccurate cuts...you could overshoot all of your outer cuts and just line up the inner dimensions right and then trim off the excess and have it look like it was perfect to begin with
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
708
You have to know the signs for winisd. IMO, it really comes down to knowing what you’re doing. Some woofers don’t model well in winisd, at all.
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
238
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
lbjshaq2345
lbjshaq2345
Johnson City, TN
ahillworks
    May 12, 2024
Brendon Jenness
    May 11, 2024
