ACC Turn On Not Working
Boomboy
Team D.O.A
this is the second deck i have tried so its not the deck, everything is hooked up correctly, the accessory turn on doesnt work though, when i put the acc to the power it works, but when hooked up to just the acc it doesnt work, this is annoying as hell because it resets itself evertime the car is shut off...what could be the issue
On the honda civic there are 2 fuses for the radio, on says radio and the other says cig or acc pwr. Check all fuses in fuse box in kick panel. You will find 1 bad one there usually a 10a or 15a. Use a DMM or Testlight on both sides to determine which fuse is bad. fuse may look good but still be bad.
Is there anything else in the car not working?
not that i can see, thats the wierd thing...will test later, gonna eat soon, results in a bit
Boomboy
Team D.O.A
Boomboy
Wisconsin
Boomboy
michigan born
    May 14, 2026
michigan born
    May 14, 2026
