AC/Amp problem
JohnT2402
This is my first installation, and it all went smoothly for the most part. Previously I had a chirping from my AC clutch, but it still worked. After I finished the install there was only cold air when it was cold outside and warm air when it was warm. As well as this, I had my sub installed for about a week when my amp went unresponsive. It is not in protection mode, just no power at all. I used a multimeter to check my ground and power with positive results. I have attempted testing my remote wire but I am unsure if I am doing it correctly (there is some static).
My amp is a Boss Riot 1100 (I know nothing great but I was on a budget), so let me know if you have had any similar problems with the amp. Any suggestions for either the amp problem or the AC problem would be greatly appreciated.
As far as the AC problem, it might be the flap that switches between AC and heat, that happened in my car once, have a mechanic look at it, should be an easy fix. As far as the amp, check the DC voltage when the car is running across the positive and negative, this should be at 13-15 V, the remote wire doesn't matter as long as it has at least 5V DC. Make sure all your wires are fine, go from the battery all the way to the amp, take a look at your fuse holder, some low grade holders will melt overtime causing a loss in voltage.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
682
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
709
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
159
JohnT2402
JohnT2402
Georgia
the727kid
audiobaun
    May 19, 2024
    May 19, 2024
