about amp
mustangmoe
i have a jl w713 and i was wondering if i should get a better amp than the one i just listed with specs here are the spcs of the sub
jlw7 13 1/2
Free Air Resonance (Fs): 23.5 Hz
Electrical “Q” (Qes): 0.476
Mechanical “Q” (Qms): 7.517
Total Speaker “Q” (Qts): 0.448
Equivalent Compliance (Vas): 3.68 cu. ft. / 104.3 liters
One-Way, Linear Excursion (Xmax)*: 1.25 in. / 32 mm
Reference Efficiency (no): 0.269%
Efficiency (1W/1m)**: 86.3 dB SPL
Effective Piston Area (Sd): 107.35 sq. in. / 0.0693 sq. m
DC Resistance (Re): 2.41 ohm***
Nominal Impedance (Znom): Dual 1.5 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.21 cu. ft. / 5.9 liters
Net Weight: 52 lbs. / 23.6 kg
Hifonics BXi 2006D
Amplifier Class N/A
Number of Channels 1 - Mono
RMS Power (4 ohms) 650 watts x 1 channel
RMS Power (2 ohms) 1300 watts x 1 channel
RMS Power (1 ohm) 2000 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output N/A
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power
Speaker Level Inputs Yes
Preamp Outputs Yes - 1 pair
Built-in Crossover Yes - LP
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 35 - 250 Hz
Subsonic Filter 15 - 50 Hz
Signal-to-Noise Ratio >95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled N/A
Fuse Rating N/A
Warranty 1-year Sonic Electronix
mustangmoe
mustangmoe
staten island n.y
mustangmoe
