Abnormal Subwoofer Output
Skanl3ss
I have 2 12" Kicker CVR bridges with a 1200 watt 2ch pioneer amp. I'm getting some where noise that's hard to describe. Also sounds like I'm hearing something that's mimicking my engine when it's on. Some say it's a bad ground or bad RCAs. The subs throb up and down violently.any idea?
check ground but u don't have rca on top of power wire do u? try a new set rcas (even real cheap ones work better sometimes) run over the seats to test it before going to trouble of removing old ones..
Could very well be a bad ground. If it's not it, then try running a set of diff RCA's.
I second checking the rca's, I had a rumble like that a while ago, I rotated the rca's and it stopped. And the grounds probably need a run over as well dude, good luck, nobody likes it when their schit doesn't cooperate with you. I also swapped my rca's for a set of rockford fosgate ones, the nib on the end of them was split, so I spread it out a touch, made for a nice tight fit.
Rotated RCA's? So in other words, switched around instead of trying another set?
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
656
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Skanl3ss
Skanl3ss
Lakewood, CA
Boomin_tahoe
    May 24, 2024
    May 23, 2024
