ability to turn off internal amp
as far as i know it can't.....but if it can wanna tell me how to do it?
....i didn't know any pio units had this feature....some of them (p9...possible p1r) don't have an amp...but i dont 'know any that have an amp and can shut it off....
Nope, you cant turn it off on the 860.
Im wondering if it will be an available feature on the new line of Pioneers.....
Yeah, for some reason Pioneer has NOT deemed it necessary to incorporate this feature into their upper end decks.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif I like Pioneer decks alot and I have to say "what a bunch of idiots".
Just curious, why do amps make heat even when they arent putting out power? I mean, heat is a biproduct of converting DC to AC, more or less, correct? So if it isnt pushing any speakers, it isnt converting that current, right?, why does it still get warm? I know its an easy answer, just never figured it out specifically...
whoops, sorry for the wrong info, good thing i said, "i believe...". i also hope the new pioneer's can do this as well because i'm probably going to be purchasing a 880prs, would like to see if there is actually a difference when the internal amp is off.
I wouldn't go as far as to call the r&d team at Pioneer idiots. It all deepends on the type of preout that they incorporate. Some HU's use the same signal for high and low level outputs. These will benefit from having the internal amp turned off. However, this is one of the poorest quality of low level signals produced. A HU that seperates the low level and high level entirely will result in cleaner preout signals and won't benefit from turning off the internal amp. Without a load on the amp, there will be no heat added. The primary reason that the ultra high end units leave out the internal amp is due to the extra cost in this manor. This is a large factor in Eclipse having such a clean signal to there preouts. With the reduction in cost over the past couple of years, more companies are using the second manor in low and mid range decks.
zachzchw
zachzchw
ohio
billybrown66
