AA poly mids question (Door pods)
iamamp3pimp
Bass Heads Entertainment
13,502
Tampa FL
if you were dealing with about .7 cubic feet of space, and you wanted a ton of midbass, and you had a pair of poly mids going into your doorpanels, that you are converting to panel/pods would you run the polys sealed, or ported.
and if you were to port them, what would an ideal tuning be?
xover point will be either 50 hz or 63 hz
-Robin
-Robin
Sealed.
/thread.
nG
never seen ported pods.
Jason had some before he got subwoofers. They were .55cubes NET with a 1.5" flared port. Got port noise because he had them play all the way down to 30hz.
Oh... probably of no interest to you. Gross highs boy.
stuff w polyfill?
if so, how much,
and if i only have a half a cube, then, how much?
thanks so far
-Robin
Generally... 1lb of polyfill per cubic foot is the rule.
Also, how will you be measuring volume? Packing peanuts?
.5cubes is HUGE... just an //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif... as far as doors are concerned.
nG
-Robin
If I had that space and custom pods in my doors, I'd sell the Poly's and go three way with an XLS.
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
I have ran the 6.5’s, but not the tweeters. They were very smooth and had good low mid bass. They were perfectly happy being high passed at 75 hz...
iamamp3pimp
iamamp3pimp
Tampa FL
///M5
    May 18, 2024
    May 16, 2024
