A Question
Most amps are just a direct connection where you strip down the end of the wire, place it in the terminal and attach it down with a screw. Some amps have a screw with that flat plate under it and those accept spade terminals. Older amps use special plugs
for what ? you talking about a lug to put 2 wires in then put it in your single input on your amp for dual feeds . or just a repalcement allen screw for your inputs on your amp ?
No not a spade connector idk its just like a soild copper peice wire goes into it and then it goes into the amp like a spade connector i gues but like a 4 guage solid copper on the other side idk
Like this?
Loudmp5
skyhigh&banginlow
Loudmp5
florence az
itsblown
