a pic for everyone to bash custom Fi IB3 18
Painting the cone shouldn't make any noticeable difference in performance. Im not sure painting the cone with gloss black was a great idea tho, flat black would have probably looked better imho.
wow, little common sense goes a long way
thanks for your input //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I hate flat black, I love shiny glossy lol, just my personal pref.... the cone was already flat black, glad it worked out the way it did //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So... did you know what infinite baffle (IB) was before you bought the sub?
I'm just curious.
Yes, and I do not believe there is a such thing as an "infinite baffle" sub. The only way this particular driver is different than a "normal" driver is it has a smaller motor, a low BL.... but for my applictaion that's perfect... because I love HUGE low tuned boxes that require less power to begin with, and I love to play for long periods of time so this well vented pole piece helps a lot. If I was going for a 4 cube box and a 33Hz tuning, I wouln't have selected this driver, or, if I was going for 5cubes or less sealed.
Yes, and I do not believe there is a such thing as an "infinite baffle" sub. The only way this particular driver is different than a "normal" driver is it has a smaller motor, a low BL.... but for my applictaion that's perfect... because I love HUGE black cocks and I love to play for long periods of time so this well vented pole piece helps a lot. If I was going for a 4 cube box and a 33Hz tuning, I wouln't have selected this driver, or, if I was going for 5cubes or less sealed.
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
so I guess you believe that every single sub is built for the same exact application then //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
thats not what i said, I suppose you think every sub with particular prefferences for a particular application can only be used for that application then
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif :rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif :rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif :rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif :rolleyes:
you stated that you don't believe there is such thing as an IB sub that all it is is a sub with a smaller magnet and large pole vent. Which you are incorrect about. the TS parameters are completely different and is designed specifically for running the sub in an IB application. Does this mean that the subs can only be used in IB setups? No but that is what it is designed for. Whether you want to believe it or not an IB sub does exist, just as subs designed for sealed or ported enclosures do.
Your shit looks ugly and is a complete fail... try this //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
Kryptonitewhite
Kryptonitewhite
soo foo sd
snfsh79077
