A new alternator or a trunk battery
The_Grimy_One
Ok, so I have a 2003 Dodge Neon SE and I am deciding whether I should upgrade my alternator or put a battery in my trunk. The alternator I will be upgrading to is a stock 120 amp PT Cruiser alternator. Yes I know, only 120 amps, but my stock is only 85 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif So this would be a quite an upgrade. My system will be drawing around 1500 watts, maybe a little more, of course this is with perfect electrical. My other option is add a battery to the back, some kind of smaller AGM, since I already have a yellow top up-front. Which would be more beneficial? Should I do one, and then later do the other? What are some good, small-ish AGM batteries for the trunk? And do I just run it in parallel with the front battery?
Thanks for your help.
alt... lets just close this thread now.. and if anyone says kinetik on the batt im going to take you outside and beat the **** out of you with a bar of soap and a tube sock... and then im going to pistol whip the next person who says shinanigans
So what batt then? Lol.
I definitely did my alternator before I thought about putting a second battery in. I actually upgraded my front battery and did the HO alternator and upgrading all of my factory charging/starting and ground wires. I don't plan on adding a battery in the rear unless I upgrade either of my amps.
Ok, thanks bro.
Get a HO and big 3. then when u can upgrade ur battery up front, I like running yellowtops up front and xs,batcaps in the back. but I would buy a HO first most important.
Sounds good. I have a yellow top up front right now. I have a special plug alternator so its almost impossible to upgrade that wire, but I did upgrade my 6 grounds, (yea my Neon has 6 grounds!).
kinetik hc600 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
shenanigans //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
bring it //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I agree both. A larger alternator (larger than 120A) would definitely be beneficial, but a bare minimum I think you should get the 120A and another battery.
1500 watts of output, assuming 80% efficiency is 1875 watts drawn from the system. At 14V that's approx 134A.
Yeah but we don't drive around with sine waves playing. Music will use 20% of that and only peaks will pull upwards of the 130a's. Well unless hes doing SPL comps but if hes just listening to music that should be enough.
The_Grimy_One
The_Grimy_One
Phoenix, AZ
The_Grimy_One
