A mild sound upgrade to my reg cab Ram
This will not be anything to brag about but I'm hoping to get a good sound with a little volume to it.
After installing an amp and woofer in my sons truck I got the itch for something better in my truck. I'm looking forward to enjoying my music instead of just hearing it. I wanted nav, crack up camera, and separate RCA sub out puts, The Clarion nx404 fit the bill for a decent price. I then replaced the 4 factory 6x9's with Memphis 6x9's. That set up sounds ok but the volume has to be at least 3/4 before you really hear it. A sub and amp will be next!
Mandatory pics
The truck
Clarion NX404
Door
Rear
Now that I removed the factory storage bin from behind the seat I realise that I have a lot more space back there than I thought! I might try to build a better box for the sub. I also have a pair of 12's that I'm considering, it will depend on how it sounds once everything is installed.
New amps and sub! On highs/mids a Rockford Fosgate 300x4, for the sub a Rockford Fosgate 1200.1, and one Soundqubed 12......MUCH BETTER! I'm in the process of getting the amps mounted but heres a shot of the sub and enclosure that I built for it.
Another thing that is overlooked is making a proper seal on your speakers and then sound deadening the doors, sealing up all the gaping holes on your door turning the door into a proper speaker enclosure will make things sound a helluva lot better.
I live in Eunice not far from you it's nice to see someone on here that's in my area. X2 on the deadening, should be a good set up.
Get the vehicle you want first then come back and see about some recommendations. Id also recommend placing some power on components,as HU power...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
979
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
986
Peter_O
Peter_O
Ville Platte, Louisiana
LosIsATool
audiobaun
    May 19, 2024
    May 19, 2024
