a little weak
  • 4
zjltwins85
15
Elon, NC
Ok this really isn't a problem, but i was wonderin....
I have 2 12' Infinity refrences in a Ported box being powered by a profile california 800sx. But it doesn't seem that loud. There is nothing wrong with it, but my friends have cheaper subs with less power and they seem a lot louder. The only difference is they have asealed box. I thought ported would allow you to feel it as well as hear it, but I can barely feel it. It's enclosed in the trunk of my car, and my car is not an open air interior.
Try changin the ploarity of your subs, instead of +to + try +to - and so forth and just try that. It helps mine out alot if I do that.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yes I have rear speakers. they are 4 1/2
The box is a Bandpass. It's dimensions are
32 1/4-wide
19-depth
14 Height
3- width of port
5 1/4-depth of port
It has regular wiring.It's not in series, or in parallel. Each sub is wired separately to a + and a -
4 gauge for Power
4 gauge for ground
10 gauge for Speaker
I can't bridge it because that will reduce it to a 2 ohm load, and my amp doesn't work well wewith that. Or so I'm told.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
12
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
8
589
Done all that with a multimeter and voltage was reading the proper voltage. Alternator reading 14.4 battery charging. Battery resting stage at...
13
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
zjltwins85
zjltwins85
Elon, NC
zjltwins85
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
