cayneismyname
Hey guys, I am wanting to purchase the following gear for my girlfriend for christmas. I just want to know if it is all compatable. I know I won't be getting the max out of everything, but this is fine as we both listen to metal music.
Any help would be deeply appreciated!!!
Thanks in advance guys.
- AMPLIFIER - 1X
Pioneer GM-5300T
Maximum Power Output
250 Watts x 2 or 760 Watts x 1 (bridged)
Maximum power output (EIAJ) @ 14.4V
Continuous Power Output - Watts RMS
@ 14.4V 20 ~ 20kHz into 4 ohms 125W x 2 (0.08%)
20 ~ 20kHz into 2 ohms 190W x 2 (0.8%)
Bridged into 4 ohms 380W x 1 (0.8%)
CEA-2006 Amplifier Ratings
Power Output in Watts RMS @ 14.4 Volts
4 ohms @ ¡Ü 1% THD+N 125W RMS x 2
Bridged into 4 ohms @ ¡Ü 1% THD+N 380W RMS x 1
Signal-to-Noise Ratio 75dBA
Dynamic Power 130W @ 4 ohms
- SUBWOOFER - 1X
Pioneer TS-W257D2
Design and Specifications
10” Dual Voice Coil (DVC) Subwoofer for Enclosure applications
1,000 Watts Max. Power Handling350 Watts Nominal Rating
Qts = 0.48
Xmax = 10.4mm
Fs = 37.8 Hz
Vas = 19.1 litres
Frequency Response : 18 ~ 600 Hz.
Efficiency : 87 dB
Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms)Delivered with “jumper link”: ready for 4 Ohm use
f0 (Lowest Resonant Frequency) : 37.8 Hz.Recommended Sealed Enclosure : 18.4 ~ 35.4 Litres
- SPEAKERS - X4
Pioneer TS-A1672S
Design and Construction
3-Way Configuration
220 Watts Max. Power Handling
35 Watts Nominal Rating
Frequency Response : 30 ~ 33,000 Hz.
Efficiency : 90 dB
Impedance : 4 Ohm
f0 (Lowest Resonant Frequency): 72 Hz.
Crossover frequency : 4,500Hz
- AMPLIFIER - 1X
Pioneer GM-5300T
- SUBWOOFER - 1X
Pioneer TS-W257D2
Qts = 0.48
Xmax = 10.4mm
Fs = 37.8 Hz
Vas = 19.1 litres
Efficiency : 87 dB
- SPEAKERS - X4
Pioneer TS-A1672S
3-Way Configuration
Efficiency : 90 dB
Impedance : 4 Ohm
