A freak accident made my buddy's system louder. Can someone explain?
  • 6
Tehgregzor
Enjoys loud noises.
1,438
Murray,KY
So my friend Jason got an Audiobahn 900 watt one channel amp. He had some pawn shop style speakers in one of those prefab bandpass boxes. So i hooked it all up for him, then tuned it to the level i figured this kind of equipment would put out. Fast forward one week, we're all drinkin beers and he pulls up and his **** is wanging hard! I asked him if he got some better subs, and he showed me where on the amp, one of the RCA's got unplugged while putting groceries in there. He was gonna plug it back in but on the way home his subs got way louder, in a good way. What would cause this?
TL;DR: two rcas plugged into amp sounded good, one rca plugged in it sounded great. Why?
I'll check polarity on the speakers. Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It's funny that this came up because this actually has happened to me before. I have had a mono amp with 2 rca inputs which was louder with only one rca plugged in. I have a theory as to why this is; I think the input voltage was too high with both rca's plugged in. There are some amps out there that do not perform better a higher rca input voltage.
If I were to venture a guess I would say the signal phase on the rca's are 180 out. cancellation causing the amp to play better with 1ch input instead of 2. How are the rca's connected to the system. Were they fabricated in a factory or did someone connect the ends on themselves?
Yes, what Dox said. The ++ -- makes it so you don't have to shove 4 wires into 2 connections. Convenient.
487
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
821
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
834
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
985
Tehgregzor
Enjoys loud noises.
Tehgregzor
Murray,KY
CrossoverOre
