LonewolfDJ
Ok check this out, here is my situation. My equipment is as follows:
One Alpine MRV-1507 amp wired at 1 Ohm on 2 Alpine SWR-1040D subs. The amp is a 1500 watt 2 channel and the subs are 1000 watt max dual voice coil ten inchers. I am running 4 guage power and ground. I am running a MA Audio brand in-dash 7" lcd which outputs to the amp and fronts and rears. I also wired into that a Pioneer DEH-p730 as an auxillary cd player. I added a Sony Playstation 2 and a 700 watt power inverter to power it. I have to problems as follows (custom sounds didn't know what to do to fix it either!):
First, when the pioneer cd player is on and the subs are powered (meaning i leave a fuse in and the amp receives power), the subs go crazy (hit super hard super fast) when the screen opens and closes, the doors open, or the car starts. I have no clue as to why this would happen because it never did it before I added the Pioneer cd player and it has nothing to do with the connection from the screen to the subs. The only difference is that the amp was at 4 ohms before and is now at 1 ohm. This blows fuses quite quickly.
The other problem: When i have the power inverter turned on and the playstation 2 on, i get a constant low frequency humm over the subs which can't be stopped unless you pull out the fuse and disconnect the amp. This only happens when I have the screen turned onto the input for the ps2. The inverter and ps2 can be on and if the screen is on the radio or the cd player, no humming..... Its somewhat loud also.
I'd appreciate any help anybody can give me for this problem. My car is a 1997 mitsu 3000gt. I have no caps as of yet but may be getting some very soon! Lonewolfdj@charter.net. John
