99 expedition build idea help
That B2 I suggested would deliver 700-800watts to one D4 sub at 2ohms...then a simple matter of adding the other D4 sub later would drop the amp down to 1 ohm for 1400 watts rms.
I did look at the scone a bit. I'm going to read reviews tonight
I'd like to thank you guysfor being so helpful
well, I was just trying to put up solid components that can be had for decent prices. In this game, as I am sure you know, You can spend a lot more and get a lot less, if you are not careful. Or spend a little here and there and still end up wishing you had spent differently. The best advice I can give, is look at all angles from equipment fit to electrical upgrades requred. Come up with a plan and stick to that plan.
well good news and bad guys... (good) so i was given a 1995 ford explorer, i also emailed hat audio to find a dealer and i really think im going to use the idea that quackhead gave... (bad) i really like offroading more than car audio so i am going to build the 95 ford explorer into a dedicated offroading camping/ fishing veh before i get into buying subs and sound deaden my expo. but i still will do the front and rear stage...
so thanks for all the info and ideas you guys gave me. once i get my door speakers i will again call on you for amp ideas
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
Many whom bypass the OEM amp, tap into the harnesses there. It is all there in one spot so no need to remove panels or runners. Just Google 2017...
The Regulator for my car is built into the harness, I keep forgetting that VAG cars are fucktarded sometimes.
16
lunchboxlust
lunchboxlust
Carthage, NY
RangerDangerV2
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
