98 Mustang - Horn wont stop honking.
that "panic mode" and horn beep for door locks is what's considered a factory alarm back then.
Constant 12V+ Yellow Ignition Switch Harness
Starter White/Pink Ignition Switch Harness
Ignition Tan/White Ignition Switch Harness
Ignition 2 Black/Green Ignition Switch Harness (A.C.)
Ignition 3 Gray/Yellow Ignition Switch Harness
Accessory Gray/Yellow Ignition Switch Harness
Tach Tan/Yellow Coil
Neutral Safety Wire White/Pink Ignition Switch Harness
Brake Switch Green or Red/Light Green Brake Switch
Trunk Release Purple/Yellow (+) )T Switch or Driver's Kick Panel
Trunk Pin Black/Pink (+) Light in Trunk
Parking Lights Brown (+) Driver's Kick Panel
Head Lamp Yellow/Red (+) Light Switch
Factory Disarm Green/Purple (-) Driver's Kick Panel or Anti-Theft Module in Trunk
Door Trigger Black/Blue (+) Or Gray Driver's Kick low under Carpet
Door Lock Pink/Yellow (-) Driver's Kick w/Keyless Entry Negative Trigger
Door Unlock Pink/Green (-) W/o Keyless 5 Wire Locks
Horn Wire Yellow/Green (-) Ignition Switch Harness
Windows Up LF=White/Black, RF=White/Yellow, LR=Gray/Orange, RR=Red/Black
Windows Down LF=Yellow, RF=Tan/Light Blue, LR=Yellow/Blue, RR=Yellow/Black
find the bold and underlined wire
you said you couldn't get the positive off the battery. if you take off the neg it'll still kill the car.
Oh, thought that was bad. Anyways. i got the positive off. I don't know weather to take it to Ford or ware i got the alarm. When it comes to trouble shooting and wiring I am worthless. Thanks for your thoughts guys.
Yeah, i did re connect it and it was still doing it. I don't know. Ill take it to the joint I got the alarm. I looked at my receipt and I got it 1 year ago to date lol!
if you have full coverage on the car drench it in gas and burn it...your neighbors will be witness to the horn sounding all evening and pass info off as an electrical short to the insurance adjuster...
x2
Just take out your audio equipment.
But other than that, the people probably just went around the stock alarm and didn't unplug something... those people are lazy like that.
When I installed my alarm the people who installed the alarm prior left about 20 feet of wire (I'm not kidding) rolled up under dash, wrapped around nearly everything...
To that day I use that wire for lengtheners and the sort.
x2Just take out your audio equipment.
And it worked for a year without incident? Dont think thats what it is.
Yes I do, but I think the car is worth more than the $3,000 or so they would give me.
Not on Craigslist =\
But, yeah... something probably shorted out between the two units. Probably something having to do with your ignition which is getting wiggled when you turn your wheel... either that or one / both the units are by your wheel column.
dave_damage
Soundstream Nut Swinger
dave_damage
Gary, Indiana
IDSkoT
