that "panic mode" and horn beep for door locks is what's considered a factory alarm back then.
Constant 12V+ Yellow Ignition Switch Harness
Starter White/Pink Ignition Switch Harness
Ignition Tan/White Ignition Switch Harness
Ignition 2 Black/Green Ignition Switch Harness (A.C.)
Ignition 3 Gray/Yellow Ignition Switch Harness
Accessory Gray/Yellow Ignition Switch Harness
Tach Tan/Yellow Coil
Neutral Safety Wire White/Pink Ignition Switch Harness
Brake Switch Green or Red/Light Green Brake Switch
Trunk Release Purple/Yellow (+) )T Switch or Driver's Kick Panel
Trunk Pin Black/Pink (+) Light in Trunk
Parking Lights Brown (+) Driver's Kick Panel
Head Lamp Yellow/Red (+) Light Switch
Factory Disarm Green/Purple (-) Driver's Kick Panel or Anti-Theft Module in Trunk
Door Trigger Black/Blue (+) Or Gray Driver's Kick low under Carpet
Door Lock Pink/Yellow (-) Driver's Kick w/Keyless Entry Negative Trigger
Door Unlock Pink/Green (-) W/o Keyless 5 Wire Locks
Horn Wire Yellow/Green (-) Ignition Switch Harness
Windows Up LF=White/Black, RF=White/Yellow, LR=Gray/Orange, RR=Red/Black
Windows Down LF=Yellow, RF=Tan/Light Blue, LR=Yellow/Blue, RR=Yellow/Black
find the bold and underlined wire
