96 Camry Wall Project
x2 on both... Seems like RF/Kicker just throw out random numbers on them. I've seen like 5 Kicker KX2500.1s w/ 2951 watts on their birthsheets. Thats a little ridiculous that all 5 have the same exact wattage.To the OP - First wall builds are always fun, just take your time and make sure u do things right the first time. ***** when u mess up a small step and don't realize it until almost the end of the build lol.
This should be a good one though, always been a huge fan of BLs.
im pretty sure there were lots of the amps built and sold, how many different numbers of watts do you think youre going to get?
you might wanna tint the rear window before you build the wall.
as for starting the floor or whatever... just cut a piece of wood and put it on the bottom part of the seat and figure out a wayt to bolt it down. it's ok for it to lay down at an angle.
backseats are useless, I support this wall //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
BLs are champs I've had mine for a year-ish now and it survived me.
Walls are sick but seeing out of rear windows is nice...
...but that's why you have two more mirrors, gl with it cuz.
Finally the day has come. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I will start the build tomorrow morning around 7, hopefully.
I have actually decided on a different approach to the wall, so.. well, it will be more like a half wall... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
It will be much easier and I will get almost the same effect, I will just have to use the room in my trunk as well. I decided to go this route because this will keep the look I am wanting to create in my car. Annnd frankly I do not think I have the skill alone to do the task up to my standards, yet //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.... I will be doing all my interior black and ill be upholstering the enclosure with black suede. Ill revamp the interior throughout.
I will be posting all of pictures and explanations tomorrow night.
Sorry again for the full wall letdown //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Still this thing is going to be HUGE! Still aiming for 18cubes!
don't see you getting 18 cubes without doing a wall, but GL anyway.
I've got about 17.5cubes in my Altima and it's a wall that also goes into the trunk as that was the only way to get the size I needed.
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
thegage
thegage
C-Town, Arizona
mlstrass
