93 cherokee 4th order wall build
ok so the 8s dont fit too well on the bottom of the panel, they hit part of the seat. so im thinking about this. it puts me at 8 mids per door which works out better for powering them too.
i may even run 2 10's in place of those 3 8's on the top...what do you guys think?
sorry this is such a slow build, but im building it little by little.. i have 3 other cars and a dunebuggy so this is kinda on the back burner lol
but heres some new interior pieces i had wrapped
need to go to a junk yard and get a passenger kick panel
seats..not sure if ima do gray with black accents yet or what..the wall im thinking gray as well, with black port/inside of box.
the dash will be dyed black.
these pieces arent attached yet, theyll be wrapped in gray tweed then screwed or nailed in with place, prally will use finish nails now that i thought about it. tweed will hide them pretty good.
one more pieces at the bottom to make, it was raining and was hard enough to finish the large front piece in between waiting for the rain to slow down, ill cut and cover that last piece tomorow. the plastic behind the trim panels that is still exposed will just be painted with some textured paint that is nearly the same color as the tweed (gray with black specs in it) and it should blend well.
This is insane! I love the idea of the carpet covering most of the interior, It looks amazing!
What subs have you decided to run after all?
I as well don't like the arm rest brown.
I should have known when I started this not to get to far into it........and I got to page 5 and said F it as pics were lacking and knowing your Mini....and of course, sold.....
Would have been sick if finished though. Hopefully your buddy finishes and puts it up here for all to see.
orangecounty1
orangecounty1
Tampa, FL
orangecounty1
NorthFramingham
    Jun 30, 2026
