93 Cadillac Deville Power Wire Running Help
AAckley1
Mr. Do-It-Big
So I have finally gotten around to puttin the system in the Caddy. Subs haven't been decided on yet, thogh most likely it will end up being AA Assasins.
So I am running the setup for my front and rear stage right now.
Went to go run the power cable and Can find no where to run it through the firewall:mad:
Anyone have experience with running it on early 90s model Caddys and where did you Run it?
Pictures would be helpful
On most of the big GM luxury cars you can drill high on the driver's side firewall between two large plugs. If you pull off the shroud over the top of the firewall under the hood, look for two big, square wire plugs at the top of the firewall. Cut away the rubber lining and drill your hole right between them.
AAckley1
Mr. Do-It-Big
AAckley1
Indianapolis
green4money
