8ohms..Help
jeepsrock
I ordered a c12 subwoofer from ikesound assuming it was a 4ohm (WEB page didnt say) . I ordered it and today recieved a 8 ohm version. My question is their anyway i can operate this sub by itself even tho its 8 ohms or will i need to exchange it for a 4 ohm version.
My amp is a US acoustics USX-4085, and was hoping to bridge ch 3 and 4 for 240W @ 4ohms MONO.
So what you think i should do now.
Pete
You could hook it up to your amp. But you wouldn't get
240w from your amp @ 8 ohms. More like around 120w.
Which for that sub is enough power. You'll be surprised how
well the C12 will perform with low amounts power.
And being 8 ohms you could always add another C12 later to get
a 4 ohm load for your amp. 120w for each C12
Or
Call IkeSound and see if they have any 4 ohm subs. If they
do send yours back and get the 4 ohm version.
I would try the 8 ohm sub first and see how you like it.
The power range for the C12 is 30-150w RMS
The 120w @ 8 ohms would work fine for that sub.
You don't need the 240w to make that sub perform.
And if you add another one later the ohm load would drop
to 4 ohms, which would be perfect for your amp.
Plus you won't have to deal with returning your sub and
waiting for another one.
Originally posted by jeepsrock Does my opinion make any sense to anyone...
If i exchange it to A 4 ohm woofer will i still have the ability to use two of them later on.
Pete
If you add a second svc 4 ohm driver you will end up with a 2 ohm load, assuming that your amp is 2 ohm stable (which you should verify)....you would get somewhere around 240 per sub....which would be a rockin setup......the only thing I am not sure of is my unstanding of bridging channeles is the amp sees half of what you actully have (because they are wired in parallel) which means that 1 8 ohm sub would actully be seeing 4 ohms if they are bridged......someone may want to confirm that, but that is my understanding.
So can someone give me the pros and cons of keeping the 8 or going for a 4 ohm version. Will the diference in sound (the bass) be different. Will it make it more difficult later for me if i would like to get another if i go either way.
I am sure you guys know how it is i am just uncrtain of whatever route i take.
Pete
nope....its just a level of resistence.......should sound fine either way......the lower the ohm load the less resistence the amp will see.....
ps if u need some help feel free to im me on aim or msn
jeepsrock
jeepsrock
Northridge CA
MikeofTulsa
