8k rms sub
Which sub?
  • DD 9918 SC
    Votes: 0 0.0%
  • FI Omega 18
    Votes: 0 0.0%
  • Something else (please post)
    Votes: 1 100.0%
  • Total voters
  • 5
Navy1527
24
Merica
Hello all,
My sub setup for my new build is two DD9918's or two FI Omega 18's. The amps will be two Banda Viking 8002's or one Banda Viking 15k. I have concerns that 8krms may be a little too much for the subs. The subs would be in my daily driver but I won't ride around full tilt 24/7.
I have 4 team AAs and they handle two taramps 15ks just fine.  You'll actually want bigger amps that that to keep the power clean with Brazilian, you'll find out that its not the subs limiting, its the amps since you cant wire low to get more power out of it after rise.  I wont hesitate to put a 15k on both subs if going with those sub choices and only wiring to 1 ohm.
The amps will be at 1 ohm. I've heard that the amps are damn near 9krms @ 14v.
false.  Anyone that's ever did a legitimate clamp will never see anywhere near 9krms wired to 1 ohm reactive load.  You'll always be rising to 2.5 ohm to 4 ohms depending on frequency. Thats the power you should expect from the amp only wiring down to 1 ohm. This is why others choose Korean amps and wire them to the dirt for more power. With Brazilian amps, you just need a much bigger amp to counteract this.
Are you saying that box rise will cause the amp to put out 7k less than what's its supposed to? I know its not the best amp in the world but damn. lol
I've been out the game for a while lol. Where can I find additional info on the box rise witchcraft? JK I know how to use google lol
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
Thank you guys! I will lower the gains with the multimeter as I have watched the youtube.
Yeah I tried that, didn't make any difference. Thanks for the time mate, appreciate it alot.
21
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
857
Navy1527
Navy1527
Merica
Navy1527
    Apr 28, 2024
    Apr 28, 2024
