89' BMW Stereo Install
skrilla22
Ok i'm trying to install my buddys pioneer head unit in his car. He has a 1989 BMW 525i. He used to have an old blaupunkt in there but he spilled coffee on it so he asked me to change it out for him. When i took out the blaupunkt, i noticed that the colors for the bmw are a lot different. So what im trying to figure out is what colors are which so i can connect the right ones and hardwire them together. The harness on the pioneer have colors that are totally different than in the BMW.
I tried looking for wiring diagrams, such as the12volt but have had no luck. Does anyone know where to get some information on this i am stuck.
So far i have - (via http://www.the12volt.com)
White/Purple - 12v
Brown - Ground
thats it.. any help would be greatly appreciated, thanks.
i THINK i have a wiring harness at home
does the car still have the factory harness?
if not you can google the "89 bmw 525 radio code"
i ha an e30 and it was a ***** to do anything in it
There isn't an aftermarket harness for those old bmws. plus, most of those were either amped or common ground. Typically the blue wires twisted together are the left, and the yellow wires are the right. (maybe the other way around, but i'm pretty sure i have it right) Sometimes too there is a fader switch right above the radio in those. If that is the case then you can usually just hook up the front speaker wires to the input on the fader switch and go from there.
Those cars ar a pain, good luck.
skrilla22
skrilla22
Tacoma, Washington
BobbyDD
