880 Not working right?
Unsure of the settings.. but even with what you said. I dont see how stock 6.5's could drown out 2 Type R's off a 2500D, or a 12W7 off a 1/1000, or two W6's off a 1/1000. I've installed all 3 of those systems on this HU. Same result, little to no-bass.
You really need to check the settings. I don't care what amp you have on what sub, if you have the sub crossed over wrong and your sub level is set really low on your deck it will not be very loud. That great big amp is only as loud as the preamp signal being fed to it.
Yes.. but I'v checked every setting. At least 5-6 times a peice. Adjusted every setting 5-6 times a peice. Checked all wiring 2-3 times, ran new RCA's. No way its user-error by now. Thanks for all the advise tho. Good to see some members are still helpful around here. Sending it back to see whats wrong..
But you just posted this earlier.
Have you or have you not checked the settings.??
If your sub level on your deck is turned way down you will not get much out of your subs.
If they are on and turned up a little and crossed over right then there may be a problem with your sub outputs.
Digital B
Here Comes The Boom
Digital B
NC
coolahan
