8" sub ?...
btw tha 2 8's r going to be for mid bass....oh and btw there going to be powered by 2 800watt rockford fosgate amps...
What frequency range do you plan on using these ?
Because if you plan to use them as actual midbass drivers.......then you don't want an 8" sub....you want an 8" midbass. Just because a subwoofer is small in diameter (8", for example) doesn't mean it will play well into the midbass frequency range.
Also depending on frequency range (i.e. midbass) you probably won't end up actually utilizing 700w even though that may be how much power the amplifier is capable of producing. So having tremendous power handling may not be as big of an issue as it may seem.
nativeboy
PIMPING JOKER
nativeboy
Flagstaff, AZ
nativeboy
