7k rms...
bgordon
160db bound !!!
Need a quick answer I'm at work and don't have time to research...
My question: what's the electrical required for a 7krms amp now here's the sub question lmao: what's the electrical I would need for daily bass, also what's the minimum electrical I woul need for burping 7k,
Alternator wil be the 250 amp power master, 1 run 0 gauge,
If mainly how many batteries would I need in the back for burping power to daily bumping power !
Anddddddd go !!!
Need a quick answer I'm at work and don't have time to research...My question: what's the electrical required for a 7krms amp now here's the sub question lmao: what's the electrical I would need for daily bass, also what's the minimum electrical I woul need for burping 7k,
Anddddddd go !!!
Well first off what amp or amps will be used ? And 1 run of 0 isnt gona work..gona need 3 runs of pos and 3 runs of neg..and those power master alts arent that goo..so i d say a good agm under the hood and 4 g31 agms in the back .would be a good start..and if ur asking whats the minimum i can get by with on that much power ur gona have issues and broken equipment soon
^^ agreed. If you are trying to cheap out on electrical, you need to stay far clear of anything around 7k.
Lol its all dependant on the amp, Korean lots of batts, Brazilian need more amperage and can get by on one batt
---------- Post added at 10:45 AM ---------- Previous post was at 10:44 AM ----------
For burping ur alt will be fine
I only have 1 run setup aloft now but I don't have the amp installed and am now deciding on running it at 4 ohms so just tryin to get an estimate of batteries for the back of to jeep liberty,
I have two runs to back and 4 group 31's and my ct 7K rarely goes down to 12.0V.
Sweet sounds good man, I won't be wide open all the I'm I work 12hrs a day so it wont be playing to crazy unless I go To a show, I just want to make sure my amp stays safe for sure but I have to worry about room, what size alternator are you running?
No need for more then 2 runs of each ...
here's a dumb question for you. i'm going to be doing a new build soon bigger than i've done in the past. now the multiable runs of pos and neg from the front are those coming off the front batt or straight alt or both of the two? multi negs from batt? Thanks, sorry op for jumping in your thread, Lol
How much power ? And a run of pos and neg from the front batt back .. Plus one pos run from alt back to rear bank is the most you should need .. Unless your running multiple alts / batts upfront any more wire then that is just a waist ..
Not saying more runs would help u but i dont consider dropping into the 12s good voltage ..i drop to 14.2 full tilt
---------- Post added at 02:14 PM ---------- Previous post was at 02:13 PM ----------
You need to go to sams and pick up the duracell agm g31s they are 170-180 each
bgordon
160db bound !!!
bgordon
Central Kentucky
vetkilr
