6x9 or 6.5 for rear fill?
But, I've read so much stuff about not having tweeters in the back.
I've done a ton of set ups with speakers in the rear. At most it can pull the sound/stage back some, but you can also turn down the rears a little if that's a problem.
I'm older and grew up in a time when cars only had speakers in the rear deck, so maybe that's why it doesn't bother me.
I prefer to try things and form my own opinion as there at too many "experts" on forums...
Would this be difficult to set up as my first amp? I can't find any documentation on it.
Shouldnt be any issues as adding any amplifier.I have the original specs booklet if you ever need any information on the amp,and can make a copy to send..Its like 14pgs.Thats an excellent amp/Zed Audio Made
OK, so US Acoustics 4050. Now, could some explain the idea of bridging the rear speakers? The front components are 2-ohn, so I'm assuming I'd have to connect the rear speakers in some way to match the resistance?
I wouldnt bridge the rear speakers..run them in stereo mode @4ohms .Bridge with another amp for a single sub, or a pair @1/2/4 ohms if considering a sub woofer.If you are considering running the 2ohm of components up front that they are, in stereo @2ohms will be more power from the amp.I run 2 sets of 4ohm components which brings me to a 2ohm stereo mode.With that US Acoustics, you can run those rear speakers and a single sub at the same time/tri mode, but be more of stereo mode,not in mono/mode for real lows, but you can run stereo mode.If that amp continues to be on ebay for that low price of under $100 bucks, Im gonna have to grab it up!! Keep the front @2ohms will not pose as an issue with the rear being @4ohms at all.
ledvedder
ledvedder
NJ
audiobaun
