Rockford Fosgate 400x4, 200IX, amp spacer, and P.G. fuse and distro block.
They are oldies, rare, and in pretty **** good condition for their age. There 2 small scuffs between the fins, otherwise they are near perfect. Even the back panals are in excellent condition. To give you an idea of how underrated they are the 200IX is rated 400w rms @ 4ohms bridged, many have gotten over 500w out of them.
400x4 Rated specs:
13.8V
4ohms - 50 Watts per ch, less than 0.05% Total Harmonic Distortion (THD)
2ohms - 100 Watts per ch, less than 0.1% Total Harmonic Distortion (THD)
4ohms bridged - 200 Watts per ch, with less than 0.1% Total Harmonic Distortion (THD)
14.4V
4ohms 60 Watts per ch
2ohms 130 Watts per ch
4ohms bridged 260 Watts per ch
Signal-to-Noise Ratio (A-weighted) >95dB
Factory Default Crossover Point 100Hz Butterworth
Crossover Alignment 12dB/octave
Dimensions 95⁄8"W x 135⁄8"L x 25⁄8"H
(24.4cm) x (34.6cm) x (6.6cm)
Damping Factor @ 4Ω (at output connector) >150
Slew Rate 30 V/μs
IM Distortion (IHF)
B+ Fuse Size (external to amplifier) AGU 50 amp
Input Impedance 20k ohms
link to manual:http://www.rockfordfosgate.com/rftech/library/1995/3_Amplifiers/MAN0993A_Punch_400x4_MAN.pdf
200IX specs:
100x2 @ 4ohms
200x2 @ 2ohms
400x1 @ 4ohms
built in crossover switchs/cards (Butterworth).
I couldnt find the manual for this one but as far as I know the THD and little ins and outs are the same for this amp as the 400x4.
I'm also throwing in (2) old school phoenix gold wire blocks. One is a fuse block with 4gauge in and fused 8gauge out. The other can be used for the ground to take the 8gauge in and put a single 4gauge out.
Askign 350 shipped OBO for everything. I'm open to offers so if you have a reasonable price i mind shoot me a PM and we'll talk.
NO TRADES
Fedex Ground
Again, shoot me an offer you think is reasonable and we'll talk
PM me with any questions.
400x4 Rated specs:
13.8V
14.4V
Slew Rate 30 V/μs
IM Distortion (IHF)
200IX specs:
100x2 @ 4ohms
200x2 @ 2ohms
400x1 @ 4ohms
NO TRADES
Fedex Ground
