50 rms amp on 20 rms speakers
the gain on the amplifier or the headunit
---------- Post added at 07:09 PM ---------- Previous post was at 07:09 PM ----------
Pioneer TS-A4674R A-Series 4"x6" 3-Way 200 Watts on OBCON OB-2800i 1000 watt 4 channel amplifier
That amp doesnt do rated anyways. Set your gains properly with an O-Scope or DMM and you will be fine.
Whats the fuse rating on that thing? I cant find anything on Google.
EDIT- There is no gain setting on the HU. Your referring to the bass/treble. Those should be set at 0/flat as well as the Loud setting if it has one. We are referring to the gains on the amp. The amp should be set with 0 Bass boost on as well.
the only thing i know is whats on amazon, i can't find anything on it
4Ch x 200 Watts Max Output
2Ch x 400 Watt Max Bridged Power
Variable Subwoofer Crossover
Hi / Lo Level Inputs
3 Way Circuit Protection
Leave the gains all the way down more then likely will be ok. Music is dynamic so only on a musical peak at full tilt would your amp deliver 50w for a split second to the speakers. You'd be surprised how little wattage your speakers are actually getting on an average.
obivouslyasd
obivouslyasd
United States
Bettr n' Revrse
