5 x 7's have more bass than 6's
I listened to 5 x 7's , 6's, and 6.5's and the 5 x 7's deifinitely kicked out more bass. So why do so many of you say they don't ??
And I assume these were in proper installations, with deadened doors, MDF rings, modelling clay, all holes sealed, proper amplifier power, etc?
The problem is, there are so much more choices available for quality speakers in "round" sizes that it's really not worth dealing with ovals unless price is the #1 concern.
I've got an 05 ford taurus and 5 x 7 is all you can fit in the doors with out major surgery. I could go 5.25 with a bracket but I didn't want to sacrifice the loss off bass, although sq would be better.
point well made, thanx.
I think you could easily fit a 6.5 in your door if you just use a drimmel or a jigsaw to cut some of the metal out of the skinny section of the speaker hole. I have stock 6x9's and all I needed was a little MDF spacer, so I'm sure you could do it if you don't mind a little cutting...
what do you do about filling in the edges? I'm sure there would be a gap at the horizontal edges
Steveopevo
Steveopevo
Silver Spring, MD
timaishu
