.5 or 2 ohm load?
cory51191
Cory
My 2 questions are at the bottom. I wanna hook up 2 Hifonics Zeus ( ZX12D2 ). they are 500rms each and my amps specs are...
- 465 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
- 750 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
- 1150 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
- Linked Power Ratings @14.4VDC
- 1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
- 1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
- Max Power Rating: 2000 Watts
- Max Current: 100A
- Full Rated Power Distortion (Max) 1kHz: 0.45%
- THD @ Rated Power 1kHz/100Hz: 0.3%
- Frequency Response Hz (-3dB): 10Hz - 250Hz
- Signal to Noise: >90
- Variable Low Pass Filter: 12 dB/Octave
- Bass Boost @ 45Hz: 12dB
- Input Sensitivity: 0.2 - 8V
- Input Impedance: 47K
- Fuse Rating: 25A x 4
- Dimensions(WxHxL) (inches): 10-5/8 x 2-1/4 x 19-7/8
-They are DVC so should i wire them at a .5 ohm load or at a 2 ohm load?
here are my wiring options http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
-What should i tune my amp to?
cory51191
Cory
cory51191
Worcester County
BloodyGuts335i
vegang
vegang
