$5 In paypal for best blow thru design
hey see if you can design some plexiglass into it as well like that one truck in the video that would be cool, but if it complicates things then dont worry about it!?
i was going to use some of that accordian boot shit like the shop told me to.. i figured i would cut a like 53x16 hole and just boot around that and mat it up! Would that work?
and how are the speakers mounted... can you take them in and out as needed or do you have to take the box apart!?
you would have to take the top off the box to get the speakers out.
i can integrate plexi but i don't have a clue what thickness to use.
plexi is a good idea, so you can see what the speakers are doing.
externally its 55 wide x 14.5 tall x 29.25 deep
that design is perfect but how m,any cubes sealed is it and what is it tuned too....? also i think 3/4 plexi should work to huh.
Is there anyway i could get a cut sheet too ill pay for that too...? but i dont want you to go out of your way to help me that much if you dont have time
1.25 cubes per sealed chamber and the ported chamber is 5.44 net tuned to 58 i beleive. It should peak in the mid 40's. Since the subs xmax is so small i had to keep the sealed chambers fairly small to help low end compression, which raised the peak a bit higher.
The subs are meant to have their motors in the ported box, to help with cooling. Thats how their displacement was figured as well.
That took me about two and a half hours....so how ever much you think my time is worth? It would only take me about 5 minutes to do a cutsheet since i have the sketchup file. 15$ would do.
There would be no problem with replacing the entire lid with plexi.
Sorry to keep you waiting, been gone all day.
tizzle2008
Beatn Down
tizzle2008
Orange, TX
tizzle2008
