Durney
Thanks to you folks my last install (on the wifes Wagoneer) went great and sounds incredible. (500/5 and four 6.5" JL components with a Boston 12").
I am now finishing my resto, a Cheyenne Super shortbed and have a couple items I want to use.
1 - the same ida-x100 as it in the other vehicles (user friendly)
2 - a "decent" amp but maybe not as nice as the 500/5, and not sure whether to get a 4 channel and "bridge" two for the sub or get a 5 channel with a separte sub channel? I really dont want separate amp for room reasons as it and the sub will be behind the bench seat.
3- NICE Speakers, but heres the quandry, I am going to use the low front kick panel openings for 6.5's and in talking to JL audio the tech mentioned I should use a coax instead of components!!... I also mentioned there were already 4" openings in the rear pillars within inches of my (and the passengers) heads and what about using those for additional 4' speakers. He said the imaging would be all wrong but if I wanted to I could simply run a set of component tweeters on the front pillars off the built in crossovers in the coax 6.5 JL's.
4- Anyone make a decent sub and enclosure for behind the bench in a std. cab?
so how about it guys ? what would you do? Coax's? Components? 6.5 AND 4"? Forget the rears? 5 channel?
