5 channel amp
Or use the nine.5 to run an active front stage and a sub stage, leave the rears powered off the HU. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
very good
ed nine.5
run the fronts crossed over about 120Hz
you could run the 3's and 6.5s in parallel (I may not)
run the rears crossed over at about 80-100Hz
you could run the 6x9s and 5.25s in parallel (I may not)
ed nine.5 will handle the impedances and crossovers.
cross the sub whever sounds good between 80-120
so even if my budget was higher for an amp the ed nine.5 would be my best bet?
the ed9.5 is on major sale, it's a pretty high end amp.
The fosgate 1000 you were looking at is more powerfull,
but to get that power will require heavy electrical upgrades.
I too am interested in the Power1000.. I have an US Amps AX5600 75x4 + 500x1... You also could look at the Directed 5 channel or the new Polk 5 channel
The new Polk 5 channel looks pretty promising. I am pretty sure that DEI owns Polk now.
corbett123
corbett123
Flemington, NJ
mike70wu
NorthFramingham
    Jun 30, 2026
