5 channel amp!
They do if you're the new RF Power series amps.
I was wondering when someone was going to bring that up.^^^LOL
The Kicker amp listed is as good if not better than the ones you listed.
What is your Budget?
Might consider a Cadence TXA-3004 or 6004 and a TXA-750D or TXA-500HC-Can get a 4 channel and a mono for around $300 shipped or so depending on the models you choose. Check it out in their outlet store.
Also check out the ed-nine.5 excellent all in one solution.IMO
If you want to spend a little more wait for the new ARC KAR 900.6 to come out.
For subs I would look at the TC-1000, IDQ/IDMAX, RE, JL, CDT just to name a few if looking for an SQ sub.
Both amps I metioned will give around 450w+ on the sub.
I don't know what your budget is but this PPI is an all in one SQ amp. Six channels, built in six way crossover, 400+ watts on the sub.
ok so give me 2 amps one four channels at least 60WRMS 4ohm and one for the sub at least 300WRMS 2ohm with the best SQ can i get arround 300 bucks both shiped!
aleborjas
aleborjas
Miami, FL
aleborjas
michigan born
    May 14, 2026
michigan born
    May 14, 2026
