goodrich
can i run the 4 channels @ 4ohm and run the 5th channel @ 2ohm at the same time on this amp? it's a Soundstream TRA 880.5
5-Channel Amplifier
RMS Power Rating:
4 ohms: 60 watts x 4 chan. + 200 x 1
2 ohms: 120 watts x 4 chan. + 400 x 1
4 ohms bridged: 240 watts x 2 chan. + 400 x 1
Double sided glass epoxy circuit board
Protection: thermal overload, speaker short, reverse and over voltage
Cooling fan incorporated directing into heatsink
HP/LP 12dB/oct Crossover
CEA-2006 Compliant
PWM MOSFET power supply
Platinum plated signal input jacks
LED indicator for power on and protection
Muting circuit for soft turn-on and turn-off
Adjustable input sensitivity control
Dimensions: 24.3"L x 10.75"W x 2.6"H
5-Channel Amplifier
RMS Power Rating:
CEA-2006 Compliant
