5 channel amp buying advice
i am wanting to use a 5 channel in my crew cab truck do to ease use an install. i have 3 models picked out an i'm not sure wich one is the better amp. i'm running a set of 4Ω components in the front doors and a set of 4Ω coaxials in the rear doors and i am running 2 12s at 1Ω. any advice would be welcomed an a great help as i have never used any of these brands before.
this is my first choice and the one i am leaning toward.
Db Drive A32250.5 5-channel 245.00
4 Ω @ 14.4 VOLTS: 4x 150 Watts
2 Ω @ 14.4 VOLTS: 4 x 300 Watts
1 Ω @ 14.4 VOLTS: 1 x 1000 Watts
second choice
Soundstream TA5.1250 5 Channel 275.00
4Ω @ 14.4 VOLTS 75 x 4 + 325 x 1
2Ω @ 14.4 VOLTS 125 x 4 + 500 x 1
1Ω @ 14.4 VOLTS 750x1
third choice
Massive Audio NX5 Nano Block Series 5-Channel 299.99
4Ω 14.4 VOLTS 120 watts x 4 chan. + 200 watts x 1 chan.
2Ω 14.4 VOLTS 240 watts x 4 chan. + 400 watts x 1 chan.
1Ω 14.4 VOLTS 800 watts x 1 channel
I would take the specs regarding the 1ohm operation above with a grain of salt. And the specs for the amps above look completely inflated to me, specially db drive and massive audio nx5. If you need such tough iron, I suggest you get a mono amplifier + a cheap 4-channel. I'd recommend Alpine MRP-F300 ($140 Class D 4-channel amp) or PPI P900.4 (4 channel amp, more power, slightly more expensive) + either Soundstream TN1.1200D or PPI Phantom P1000.1 (same board used in both, ~1200watts RMS at 1ohm).
You can get the Precision Power amps on here from me.
I do not recommend running any of those amps at 1 ohm on the sub channel. That's a lot of heat to potentially build up in a chassis with dual power supplies, and usually you have to pay a lot more to get a really good 5 channel amp that takes that abuse. You would be better off with those choices if you design the system to use a 2 ohm load on the sub channel. In theory it's only a 3 dB loss of output by cutting the power in half.
I would pass on that OBCON box you have listed in your signature. A generic ported box is a bad idea. You might have someone nearby who can design and build a really good ported box to perfectly fit out of the way.
i have already bought obcon box. i got it from a friend who had the same truck as me, an it sounded good with only 600 watts going to the kickers. i'm not a bass head i listen to mainly metal and hard rock so i'm not gonna push the sub channel to hard.
The umm1 is just a rebadged dayton/minidsp mic. I personally have a umik2 and use a regular usbc-usbc to hook it up to my laptop and a...
191
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
590
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
901
wardrebel
wardrebel
Meridian, Mississippi, United States
mylows10
pfft
    May 1, 2024
pfft
    May 1, 2024
