4x10 Question
The component speakers are circular i have no fiberglass experience of no type how could i get those in the little back deck of a 80 cutlass supreme?
If you aren't willing to spend $60 on a set of speakers for your rear, my recommendation would be to just not get any, disconnect the rears entirely and focus on your front stage. Buying a set of $40 speakers just for the sake of upgrading from stock is honestly a waste of money if you aren't going to get a quality set. Just save that money for your fronts
Alright ill do it what do you recommend ill spend 60.
Are you going to be running subs in that big *** trunk?..I had a '81 Supreme and took the deck speakers out because they were sitting right on top of my ported RF Pro 12 and they did not like that at all.
Yes im about to build a big ahh box so i can still put my spare tire in there and put two obsidian 12's in
sorry I didnt see your sig. do you still have the little cotton lined paper boxes under them inside the trunk? i had to remove mine to make the box fit between the trunk lid brackets..they are highly recommended, or some type of enclosure at least
*nevermind
as far as subs go
the trunk in that car is a PITA
the back seat is not easy to get into. just remove it.
you can fit 4-12's each in a dedicated airspace 2 cut. ft. box (8 cu. ft. total)
Teezy
Teezy
Ellenwood, Ga
Teezy
