4th order lid vibrating.
srb
I have braced the inside and screwed everything down, but the top of the 4th order still vibrates like crazy. It makes a horrible sound of the mdf slapping together.
I didn't glue it down because I wanted to be able to take the top of to check out the subs if there was anything wrong with them, and it was such a tight fit into the trunk of the car, there is no way its gonna come out again. The box was built to the max dimensions and it took five people to get it in.
What can I do? Is there any way I can stop the top flexing from the exterior of the box? Has anyone had this problem before?
Had a similar issue with some MDF bracing breaking loose, use a long piece of 3/8 threaded rod and nuts/washers on the inside/outside to keep it stiff.
That's a good idea. But I was really hoping there would be a way to hold the lid down without having to take the whole box out again, if that is even possible.
I cant double baffle the whole top as it is literally touching the metal on some parts of the trunk (I made a trunk wall). I guess I will do some more testing tomorrow to find the areas it is flexing most and try and double baffle it as best I can.
Foam weatherstripping between the panel and box. I would have assumed you already did something like this to have an actual air tight seal.
No I didn't do that. I was going to tape around the seems using foil tape to make it air tight. That seems like to would work through. That way the mdf isn't just slapping against itself.
And @Mitch86 I have been seriously thinking about ratchet straps honestly....
srb
srb
Lake County, Florida
mazdakid
BP1Fanatic
BP1Fanatic
