4th order help...
k_schutte
my first attempt at a 4th order. Running a pair of Re Audio S-E-X 10"s, on about 800watts each. Car is a 2003 Cadillac CTS.
Anyways... I need port help because my cumputer is down right now and I do not have access to my programs. The box will end up being 1.25ft^3 sealed and 2.58ft^3 ported. I want it tuned in the 45hz range, external port. Basically need to know what my aero port needs to be.
8" aero or 10" aero, whichever would be better.
I was thinking 8" myself but without the info on my computer, i wasnt sure...
8" would be good too because I am porting through the factory 10" sub hole in the rear deck. Flare will probably ennd up being about 10" when all is said and done.
So, lets go 8" aero, i need to know the length for a 45hz-50hz tune. No need to worry about port displacement or anything cuz it'll be external port. Thanks in advance guys!!
8" would be like 50"^2 port for 2.5 cubes... Seems pretty high, doesnt it?
6" aero would make it like 11.3" per cube instead of 19.3 like the 8". Not sure if it is different with a 4th order or what but.... I assume you want a good sized port as that is where the sound comes out, LOL...
talking to some local gurus, they all think I would be louder just going with a standard aero ported box. Then removing the factory sub from the rear deck so I have a 10" vent into the cabin...
Any input?
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
k_schutte
k_schutte
cedar rapids, IA
k_schutte
